So today I went out and bought 2 packs of CM MF120R ARGB 3 in 1 and also the Corsair Vengeance RGB 16GB 3200MHz. I disassembled my computer and cleaned it up, re-applied thermal paste, clean fans, install the new parts etc.... and after I was done I tried to see if it would work and everything lighted up but it didn't post or display anything. My keyboard and mouse didn't light up either. The CPU debug light was lit and nothing else. Won't post and I can't even get into BIOS.
I removed the new RAM and tried again, followed by all the RAM and also the GPU but still the same, only the CPU debug light is lit. The DRAM and VGA debug LEDs aren't lit up even though I removed them. I disconnected non essentials from the motherboard, removed all but CPU and PCIe from the PSU and left only the pump connected but still the same. Cleared CMOS countless times but still persists.
Before installing the fans and new RAM it was working fine, I was gaming and doing photoshop work no problem. There were no signs of the computer dying either.
What could be the issue here? Dead CPU or dead motherboard? Not enough power to support all the fans and RGB? The entire build is less than 3 months old. CPU, GPU and RAM are all overclocked but not too extremely.
Specs are as follows:
Ryzen 7 2700X @ 4.2GHz
Cooler Master ML360R AIO CPU Cooler
MSI X470 Gaming Pro Carbon
Gigabyte RTX 2070 Windforce
Kingston Hyper X Predator RGB 16GB 3200MHz @ 3400Mhz
Transcend MTE220S 1TB
CM MWE 750W Gold
Lian-Li PC-O11
The new parts bought were the Corsair Vengeance RGB 16GB 3200MHz and 6 Cooler Master MF120R ARGB
CM MWE 750W Gold
Lian-Li PC-O11
