Question MSI X570 Tomahawk WIFI vs. MSI B550 Gaming Edge WIFI
Dec 2, 2020
Hi All,
Due to BF sales, the X570 is very close to the B550 pricing (204.99 CAD vs. 259.99 CAD). I will be using the following components:
AMD Ryzen 5800x
EVGA GeForce 3080 XC3
g.skillz Trident Z neo 2x16 gb 3600mhz ddr4
What would be the preferred option for future proofing, maximizing frames (pc will be used mainly for gaming and occasional streaming) and overclocking? I would not be utilizing the additional pci4.0 lanes etc.
Thanks in advance.
Hey Matthew,
You dont want to game or stream over a wifi network, its NOT great.
Use a cable when possible.
Im not seeing an audio difference between the two.
The only major point as far as I can tell is that the tomahawk has more usb ports.
Lets be honest here... there arent major differences in this price bracket. at about 400 cad you can get a msi emg unify or an asrock taichi. which are great motherbaords for high end overclocking.
bottom line, I would not lay awake from A or B. I would get this ( no wifi)
else I would get the tomahark since there is also a cashback action.
PCPartPicker Part List
Motherboard: ASRock B550 Steel Legend ATX AM4 Motherboard ($218.95 @ Vuugo)
Total: $218.95
Generated by PCPartPicker 2020-12-02 17:09 EST-0500
Dec 2, 2020
Hey Matthew,
Total: $218.95
Hi Superninja,
Thanks for your response. Just to clarify, I will be wired but I like the flexibility the Wifi option provides if it's price negligible. If I was able to secure the MSI Gaming Edge for roughly the same price as the ASRock would you still recommend that one? I have researched that both MSI options I'm considering have some of the best VRM's in their class which allow further overclocking.
What makes you recommend that specific ASRock board?
Thanks,
