I have an x99 MSI board with the CPU, RAM, and GPU attached. When I turn on the power supply the board lights up including the power button and the "OC Genie" button if it is depressed. However, when I hit the power button I hear a click from my PSU and then nothing. If I press the power button I don't even get the click. However if I hold down the power button the CMOS light comes on and if i press that i can press the power button again to get the same "click".
I am getting a bit desperate at this point just because I've run through everything I can come up with to no avail. I have switched and checked all power cables, tried the ram with a single stick in all positions (as well as dual channel just to be sure), ensured my graphics card is properly seated with power attached (it does wiggle a little but i assume that's natural as its a large card), Reset the CMOS. Nothing has worked so far.
I will also note that I first tried this in the case (something I have now learned is a bad idea). That said the standoffs all appear to be perfectly properly installed. One odd things, for a while, when i would turn on my PSU parts of my case/the back of the PSU appeared to be giving me a very low level shock but that has since stopped.
Any guidance would be immensely helpful as I'm out of ideas. I don't even know WHAT to return if I need to replace things.
MSI x99a SLI PLUS
i7-5820k
GSkill 4x4 DDR4 3000
Cooler Master Hyper 212
EVGA Supernova G2 750
MSI GTX 980ti
EVO 850 250gb
WD Black 2 TB
MSI x99a SLI PLUS
i7-5820k
MSI GTX 980ti
EVO 850 250gb
WD Black 2 TB
