MSI Z170A Gaming M5 and Corsair Spec-02 Wifi Card Problems
XBlitz15
162
Hi,
My wifi card does not fit into my case. My wifi card is a PCI-E Wifi card, and it will fit into the PCI-E slot. However, even after I unscrew the wifi antennas off of the wifi card, the card is still too big, and does not fit into my case.
I found out what you meant after, that I had to unscrew one of those side parts, and then I put in the wifi card. Sorry about that.
