I have little to no water cooling experience. Just read the basics. Trying to understand if pre-built computer was connected wrong. Thank You for reading.
According to my bios and MSI command Center, I seem to be missing pump. 2 system fans are working, and the 1 cpu fan is working, but pump speed is 0. there is 2 water lines connecting to my CPU and go to the fan on the back of the case, where hot air vents out.
Could they have connected the pump plug to a Case Fan plugin ?
or, is it likely the pump is built into the loop somewhere and isn't suppose to plug into something ?
This was a prebuild Best Buy Gaming rig.
My cpu temps stay between 40c and 60c.
i77700k
msi gtx1080
i77700k
msi gtx1080
