[SOLVED] MSI Z390-A PRO ATX LGA1151
Apr 21, 2020
6
Will MSI Z390-A PRO ATX LGA1151 motherboard fit and connect well in my Cooler Master HAF-X V2 case and will i be able to connect the motherboard with cordair vs650 corsair 75-001837 model power supply.
Thanks
yes it will fit in that case and yes that power supply will work (though, if you buy a board that expensive, you might wanna get a better quality power supply)
