So today i swapped out my cpu, a 9600k for a 9900k and now i ran into some problems, I have a MSI z390 a-pro, wich supports the 9 series, but for some reason it didnt post with the 9900k in it, i had a Dram debug led go on when i booted. i tried every dimm slot, 1 ram stick all combinations really, wont post. swapping back to the 9600k everything worked as normal. i also tested the 9900k in a different system and it worked perfectly fine. So i redid it, same Dram light went on so i tried a old ramm kit i had, wich worked, but once in windows my ram was locked at 800 MHZ any try to get it back to anything above the 800mhz made it reboot with a overclock issue, i have updated the bios, and cleared the cmos.
The 9900k works perfectly fine on a b365 board, could there be any setting that is different on a z390 board, that is just a default setting (after clearing cmos) but could cause this problem between a 9600k and a 9900k.
