Hi All.
I own a Z90 Gaming Edge mobo from Msi and a Phanteks Evolv-X case. My problem is that I cannot figure out why the IO shield I got with the mobo is not aligned with the connectors once I put the mobo inside the case.
I tried to insert the mobo with or without IO shield and I took the pictures below.
It seems that the mobo sits always well in the same position in both cases (same height measured with the caliber), but the shield doesn't match. It looks like the PCB lowers down on the left side because maybe the backpanel of the case is not parallel to the rectangular hole, or the height of the standoffs is not the same... but I cheched several times and all seems fine in the case.
Has anyone got the same issue? I'm really struggling with that...
Thanks a lot. in advance for any help.
Kind regards.
Antonio.
Kind regards.
Antonio.
