AS it says,I just put this system together and the EZBUG white led for the CPU stays on,wont get any video....I am using an HDMI cable and even though I should have on board graphics with the 10600k I tried restarting with a video card which didn't change the situation.I also checked for bent or dirty pins and everything is pristine far as the socket and the chip...The chip is seated correctly. I even loosened the cooler thinking maybe it was too tight but it's actualy movable slightly,that's how loose it is so it's not a problem of the cooler applying too much pressure to the chip. I'm at wits' end here,I can't see what else it could be other than a bad mobo or chip or am I missing something? OH also tried posting with just the mobo,cooler and 1 stick of ram in the first slot,still nothing.........just the white led for the cpu on. Please help me out....build is below........another thing to add...the cpu power has 8 pins and the 4 pin,I have only the 8 pin connected as I do not have the 4 pin connector,could that be the problem? I read that onyl the 8 pin is needed and the 4 pin is just for overclocking but maybe It's needed to have both with power?
MSI Z490 Tomahawk mobo
intel 10600k chip
Corsair ICUE H150I Elite Cappelix liquid cooler
samsung evo plus 1 terabyte m.2 ssd
Western digital 4terabyte blue hdd
G skill Trident Royale 4x8 gig sticks ddr4 3000 ram
Corsair RM850x power supply
Coolermaster sl600M case
intel 10600k chip
