Heres my story.
I just upgraded from old mobo with phenom ii x4 with noctua d14 to mobo MSI Z87 and i5 4670k. Problem is the noctua is too loud. Whereas in phenom system the fans went on 800-900 rpm, now they work on max even in idle! which means around 1300 rpm which is just too loud.
Problem is the MSI BIOS says the CPU temperature is 40 degrees (eg. from computer start up) but Real Temp app says just 27 - 30 degrees.
Is there any way how to talk reason into MSI BIOS and override the fan speed? (I tried to set fan speed in Bios hardware control with no satisfactory result, all stays the same🙁
Thank you for help.
Thank you for help.
