Multi case water cooling setup
SharpSh00ter109
6
Would it be possible to run a water cooling loop through two separate cases. I want to keep all of the pumps, reseviors and radiators in their own case to show it off separately. I don't care about practical or any of that stuff, just if it can be done and would one pumps be able to pump liquid through a res, radiator, and one cpu/gpu block on each loop (two planned). Any help given is much appreciated. Also, and case recommendations to put all the radiators and pumps in?
I already seen what you are talking about on youtube with highly expensive water loops with very expensive pc's. I you are running a normal loop (cpu only) then you don't need that stuff. Just run the loop in your pc. Those case are homemade I GUESS so it may not be easy to do.
- The Brownie
500$ for that case ... wow
at least there's lot of room at the top for rads pumps and reservoirs 😛
i thinks you still can have something a little cheaper no ? ahah because getting a case 300-350$ more expensive because there's more room ?? hell no
- The Brownie
