Multi-monitor with different Resolutions
penti01
8
Hi all!
I've got a 34" 3440x1440 ultrawide for my main monitor, and an old 27" 1920x1080 for my second monitor.
Physically, both monitors line up height-wise.
However, the pixels won't, since one is 1440p and the other 1080p.
Is there a way to change the aspect/zoom/etc of the 1080p to make it look like 1440p?
ie have the 1080p process 1440p worth of pixels so that they match scale-wise?
To add, I'm running GeForce graphics, so can't use any eyefinity tricks..
Thanks in advance!
penti01
8
Just an update.
Using the GeForce settings, was able to set a custom resolution of 1440p.
While it did get scaling to work, there's noticeable sharpness issues.
I'm guessing I have to settle with one or the other for now..
