T trony Distinguished Nov 23, 2010 4 0 18,510 Nov 23, 2010 #1 Hello , we are searching for Multi motherboard case like 4 or more motherboards into it. Do you know some cheap to buy? thanks
idoop Distinguished Dec 8, 2009 93 0 18,630 Nov 23, 2010 #2 i haven't heard of a cases that supports more that 1 mobo.. what you could do is get a server rack: http://www.newegg.com/Product/Product.aspx?Item=N82E16816215189 And use server chassis for the mobos and insert them in the rack. But i dont really see another way?. I cant really recommend a server chassis for you. you could alwasy chack newegg for that : http://www.newegg.com/Store/SubCategory.aspx?SubCategory=412&name=Server-Chassis and then you could use a kvm switch to put all the cables together: http://www.newegg.com/Product/Product.aspx?Item=N82E16817107419 And if you were talking about a normal case there was one the Mozart TX, i could hold 2 mobos but its not being sold anymore... i hope this helped you
acer0169 Distinguished Apr 9, 2009 1,039 0 19,460 Nov 23, 2010 #3 ^ +1 Most people after a multi-board setup (as I like to call it) either go with work benches, server racks or build a custom case.
T trony Distinguished Nov 23, 2010 4 0 18,510 Nov 23, 2010 #4 may be custom made wood, similar to: http://www.silentpcreview.com/article237-page1.html
T trony Distinguished Nov 23, 2010 4 0 18,510 Nov 23, 2010 #5 What company builds custom case of this kind? acer0169 : ^ +1 Most people after a multi-board setup (as I like to call it) either go with work benches, server racks or build a custom case.
boiler1990 Splendid Dec 21, 2009 4,072 0 23,160 Nov 23, 2010 #6 trony : may be custom made wood, similar to: http://www.silentpcreview.com/article237-page1.html That thing is ridiculous. Also, I think you'd need to build your own case. Sounds like a great project though. It'll give you an excuse to build a new computer for the CAD drawings!
Wolfshadw Titan Moderator Aug 3, 2006 28,524 1,699 133,290 Nov 23, 2010 #7 Look to Mountain Mods for multi-board cases. Whether or not the make one for four motherboards, I don't know. -Wolf sends
T trony Distinguished Nov 23, 2010 4 0 18,510 Nov 23, 2010 #8 Hello, looked yerterday, no multi-mother 🙁
