So I was thinking of buying RGB light strips for my room
http://www.amazon.com/dp/B01689GXYS/ref=sr_ph?ie=UTF8&qid=1449809781&sr=1&keywords=rgb+light+strips
Here's my question: is it possible for the remote to control two light strips? So let's say my PC is on one side of my room and my TV on another side of the same room. I want to put the RGB strips on the backs of both my PC monitor and TV. Will I need two buy two whole separate packs? Or is there a way around this?
Thanks in advance!
Thanks in advance!
