Good afternoon and thank you in advance for any help I get. I recently moved into a custom built house, with a multi-zone audio system installed. Unfortunately the house was not custom built by me and I have no idea how to use the system to its full potential. I am a home audio NEWB, I know nothing and am looking to educate myself.
Each room in the house has a speaker in the ceiling, as well as a faceplate with IR capability, source selection and volume control.
The speakers and face-plates are wired to a mane hub in my living room, and connected to a multi-zone controller/Amp.
The only way I've been able to figure out so far how to play audio to the speaker at all, is to hook up a source, via a 3.5mm audio cable to the Zone 6 input in the amp. I then need to walk to each individual faceplate, turn it on and select the Zone 6. I would love to have each zone turn on automatically when the amp is powered on.
I could not locate a model number or brand for the controller/amplifier.
Ideally, I would like to be able to stream music wireless, via either airplay or bluetooth, I just have no idea how to accomplish this with one source of music, let alone multiple sources. At first I thought maybe an AV receiver could accomplish this, at least with one source... I came up on a Denon AV receiver that is able to be controlled via airplay. I cannot figure out how to hook the receiver to the amp to stream the music though...
Any advice is greatly appreciated. I would like to use the equipment that is already installed, if the receiver does not have the capability to be used, I dont have a problem selling it and replacing it with a better option.
Trying to attach PICS below...
if the pics dont show up, the below links should get there.
https://drive.google.com/open?id=19H4fxSRccDce8-YnbzMxwWdHSoy41IHt
https://drive.google.com/open?id=1VmVuLpMDexrkJuDqpSG_E4po4u4toReG
https://drive.google.com/open?id=19RbKKVvLMxUvTezo_fBVrI1wSzvo4wHl
