Hello all,
I'm trying to figure out if there's a way to create a bootable USB Flash Drive that can be used to install Windows 7 Home and Pro and both the 32-bit and 64-bit versions of both?
At the very least I'd like to be able to use a single USB Flash Drive to install the 64-bit version of both Windows 7 Home and Pro. I do have the actual install DVD's if that makes it easier.
Thanks for the help!
