Multimedia Audio Controller
pheno_oharra
8
Hello,
My Computer Is HP Compaq d530 SFF and Processor Is Intel R Pentium R 4 CPU 2.80 GHz 2.79. Its A 32-Bit OS, First I had Win. XP Pro SP 3/32 bits Installed with all the drivers and then I formatted and installed Win. 7 Ultimate 32-Bit Version. The graphic drivers which earlier worked in Win XP. Worked now also but the sound drivers are not working. In The Device Manager, under Sound, Video And Game Controllers it shows Multimedia Audio Contoller (without exclamation mark In yellow ) and in its Properties under General tab it shows under Device Status "No drivers are installed for this device"
What can i do? I don't find any link for download.
Thank you for help me,
Pheno
There aren't Windows 7 drivers for it.
You can try Windows Vista ones that are available and cross your fingers.
I am also trying to figure out what chipset it uses for the audio, and maybe find Windows 7 drivers for it that way.
Worse case, you can install an audio card, but be sure IT supports Windows 7
If Vista driver doesn't work, you can try this:
http://www.helpjet.net/dl/84985774-99864739-93623844/24...
You may get lucky.
You may get lucky.
