Multiplayer Using WiFi Or Ethernet Cable
Podimon Jackdaw
55
I have a Desktop PC, A Laptop, Wireless Network To Connect Both Systems To Access Internet , A LAN Cable To Connect Both Systems Together. I want to play multiplayer in these two Systems with a friend. What to do ? I have a lot of games installed and NFS MW 2005 copied but playable. I tried game ranger but when tried to session game in MW it stopped working. Which all games can be played using the things I have ? At least Most Wanted ? Help me how to do this ? Thanks.
I will use ethernet cable but how ? And what to do ? When both are connected to each other a network without access to internet appears in Network and Sharing center. I want to use it for multiplayer but how ?
Play with a friend using closely placed computers like what people does in gaming centres.
Then you need to have 2 Ethernet cables and plug each computer to the router, so you can play either LAN or WAN parties.
Note that if you did not use Gigabit Internet like Google Fibre or whatever, play with WiFi while in a same room and near the router can also achieve the same speed just like using the Ethernet cable.
So according to your reply, you only want to play with a friend locally and not an online game? If yes, LAN means Local Area Network in which means any computer connected to that network will get a same speed (of course not the Internet speed), no matter via either Ethernet cable or WiFi. So actually you don't need to have both or one of them to connect via cable, just need to be as long as both computers connected to the router in either ways. (via cable or via WiFi)
Both are connected to the same wifi network. I just want to multiplayer like in android games or in wifi enabled handheld gaming consoles like psp. I tried it in NFS MW but game stopped working. Any other games supporting my need ?
