Question Multiple Bluetooth devices connected to one PC connection issues
animemangamer
I have a Z370-E motherboard that comes with on board 2X2 Dual Band Wi-Fi and Bluetooth v4.2
I'm trying to get the following 3 Bluetooth devices to work properly:
Logitech MX Master 2S Mouse (BT v4.0)
Sony WH-CH700N Headphones (BT v4.1)
Xbox One Controller (BT v4.0)
The issue is when I connect the 3rd device: Xbox One Controller I suddenly start experiencing horrible audio pausing/skipping on my Bluetooth headphones. It basically skips or pauses audio for a couple milliseconds every 5~10 seconds.
Is this a limitation with the motherboards on-board Bluetooth adapter to handle multiple Bluetooth devices at the same time?
Because what I found out is:
  1. When I turn OFF the Xbox One Controller the audio problem of the Bluetooth headphones goes away.
  2. When I turn OFF my Bluetooth mouse and keep the Xbox One Controller ON the audio problem of the Bluetooth headphones also goes away.
Basically I can only use 2 Bluetooth devices at the same time. I wonder if there's any solution to this? Thank you in advance.
