Hello all,
Hope everyone is doing well. Could use a little help here.
Have a Corsair 1000D case which will be all air-cooling for now with ML120s and ML140s (total of 13 fans). I've never installed this many fans and have a basic question to ask. (front fans are intake, top and rear fans are exhaust)
How would you install these fans in regards to the wiring? The wiring protrudes from one of the fan's corners (obviously). Does it make a difference where that wiring corner is situated when installing the fan: bottom left, bottom right, top left, top right in relation to the case? The only thing I can think of is that the wiring corner should be situated towards the back of the case. I will be using three Corsair iCue Commander Core XT modules for the hookup.
Again, I've never installed this many case fans and could use your advice. Thank you.
Jack800
Jack800
