Im using multiple 3-pin fans that will connect to this:
http://www.performance-pcs.com/modmytoys-4-pin-power-distribution-pcb-8-way-block.html
What adapter cable do I need to connect the above link to my PWN 4-pin header on motherboard so I can control fan speed in BIOS or using software? Is there a Molex end/4-pin female end cable that exists?
I know Jayz2cents used that block in part of his Skunkworks build and was able to control fan speed
thanks for your help!!
Or would this work better - http://www.phanteks.com/PH-PWHUB.html
