Multiple keys problem
jmscreation
13
i can only press two keys on my keyboard and the third key is disabled. I tried updating my keyboard(Standard PS/2 Keyboard) but says it's up to date. I would like to get some drivers to fix this. If anyone knows where i could find the drivers, plz help me.
http://gmc.yoyogames.com/
http://www.yoyogames.com/make
You could also try Win7 32bit and see if you can get your game to run using the Compatibility options.
And you could always setup a dual boot Win7 / WinXP capability.
http://www.sevenforums.com/tutorials/8057-dual-boot-installation-windows-7-xp.html
I tried this, but it didn't change the fact that i could press these keys:
Up, Left, and Space
One of these would be disabled. If Up and Left was held, Space wouldn't work. Etc.
Hey, I partitioned a new hardrive("G:" 50 GB) and I want to put XP on it, but I don't know where to get the XP disk. Can i simply use one I've already used for another computer? Could I download it? I don't want to go buy one.
50GB is a good sized XP partition. I've been using a 40GB partition and it's been plenty - 25GB Free after initial install plus the usual add-ons like MS Office 2003, Firefox and Google web browsers and a dozen or so favorite utilities.
You'll still need to comply with the license requirements but if you have a retail copy of XP not currently in use then you're ready to go.
Latest posts
