Multiple monitor help
Mar 21, 2018
I have a Radeon Rx 580 w/ 1 hdmi port... MOBO mai B 350m with DVI , HDMI, VGA, ports...... I wish to use 3 monitors (1 Tv...hdmi)(2 vga/dvi)..... the mother board won’t recognize any monitors at all but the GPU will.......... I’ve heard you need a driver or disable the GPU to use the motherboard graphics ....... how do I do this and will the GPU be useless?
You want to run all 3 monitors from the RX 580, otherwise you'll run into the issues you're facing. You can easily buy adaptors to connect DVI to display port. If I were you I'd use the HDMI on the card for the TV and then buy 2 adaptors for the monitors.
Edit, does the card have a DVI output? I know some do, if so you'll only need one adaptor to connect the DVI monitor to the DP output on the card.
