You can't. End of story. You should have done research first. one of the DVI Ports shares the signal with the HDMI Ports. Monitors 3 and 4 must be connected via display port. You only have one display port, and there are no display port splitters on the market, so you can only connect 3 monitors. The third must use an active display port to DVI adapter
