1.So the rig that i built that is in my specs below is acting up, and by that i mean freezing. If I leave it alone for more than a couple hours, i come back and no response. For example I left it downloading Shadow of Mordor earlier today, bout two hours later i checked up on it and it's frozen. Not only that, but once I power cycled it Steam acted like i'd never added any games. Now everytime I load steam I have to reselect my game library drives. I have all my non internet games on the WD 1.5TB and the online ones on the 240 Kingston. Any ideas?
2. I have the H100i in my CM HAF EVO XB. Right now i have 2x120 mm fans on either side, both pushing outward. Is that the most efficient setup? I have another 120mm on the back for exhaust, and a 200mm on top as intake, and then two 80mm on the bottom back for exhaust. Monitoring my temps and they seem normal, never really spike. Im just worried that maybe the 200 mm isn't enough intake?
3. I recently got the CM Storm Quickfire Rapid w/Cherry Reds. It will not work on my mobo's rear 3.0 ports. It recognizes it but it doesnt respond. Works fine on all the other 2.0 ports and the front 3.0. Tested the rear 3.0's one has my mouse and it works, and before I got the CM I had an old Wyse keyboard there and it worked fine. What's going on with this?
Please help me this site is where I have learned everything I know. It's frustrating that I spent this much $$ on this rig and it's not performing like it should. Thanks guys (and or gals)!! If you can only answer one of the questions or just have an idea let me know please
