Hi,
I've been looking for a custom desktop that will last me a long time for the purpose of gaming, student work, multimedia and everyday computing. With some bad experience with laptops for all these purposes I was wondering if Desktops were a better way to go in terms of price, performance, reliability and also the ability to get parts fixed/replaced. Also I stumbled across this item " http://www.mwave.com.au/product/mwave-haswell-gamer-gtx-760-system-ab51566 " and was curious to know if it would for example run a game like BattleField 4 at an optimal level, also with no sound card that I can see on it, would this affect the quality of sound still with the use of a decent headset? Being pretty technically disadvantaged I would appreciate any advice and reassurance of this system or any others that would be of a similar price range. Also if you did suggest this system or an alternative would you recommend a certain monitor for it? I'm not sure which monitors suit which systems and wouldn't want to purchase based on a guess.
Thanks in advance for all the advice.
