So basically, I decided to download it and check for adware since I hadn't done so yet. I was then met with 7 threats (I will attach the log to this post below), so I chose to remove them. Once I rebooted I noticed my Ransomware protection in MWB was turned off, and if I tried to turn it back on it would just say "starting.." and wouldn't actually turn on. I proceeded to get a little worried and did a clean install of Windows, however after reinstalling and signing back into Chrome I decided to run the scan again, and it picked up the same 7 results, and they are still there even after cleaning and rebooting. I have no homepages set, and my only extension is Adblock Pro. I would greatly appreciate any help.
Log:
# AdwCleaner v6.041 - Logfile created 25/12/2016 at 14:38:10
# Updated on 16/12/2016 by Malwarebytes
# Database : 2016-12-23.1 [Local]
# Operating System : Windows 10 Home (X64)
# Username : Me - DESKTOP-InsertNumbersHereJustInCaseINeedToKeepThisOut
# Running from : C:\Users\Me\Desktop\adwcleaner_6.041.exe
# Mode: Clean
# Support : https://www.malwarebytes.com/support
***** [ Services ] *****
***** [ Folders ] *****
***** [ Files ] *****
***** [ DLL ] *****
***** [ WMI ] *****
***** [ Shortcuts ] *****
***** [ Scheduled Tasks ] *****
***** [ Registry ] *****
***** [ Web browsers ] *****
[-] [C:\Users\Me\AppData\Local\Google\Chrome\User Data\Default\Web data] [Search Provider] Deleted: search.conduit.com__
[-] [C:\Users\Me\AppData\Local\Google\Chrome\User Data\Default\Web data] [Search Provider] Deleted: mysearch.avg.com
[-] [C:\Users\Me\AppData\Local\Google\Chrome\User Data\Default\Web data] [Search Provider] Deleted: ask.com
[-] [C:\Users\Me\AppData\Local\Google\Chrome\User Data\Default\Web data] [Search Provider] Deleted: aol.com
[-] [C:\Users\Me\AppData\Local\Google\Chrome\User Data\Default] [extension] Deleted: gjkpcnacdgdlpfejlgflolpaigoicibh
:: "Tracing" keys deleted
:: Winsock settings cleared
C:\AdwCleaner\AdwCleaner[C0].txt - [1568 Bytes] - [25/12/2016 14:38:10]
C:\AdwCleaner\AdwCleaner[S0].txt - [1142 Bytes] - [25/12/2016 14:32:26]
C:\AdwCleaner\AdwCleaner[S1].txt - [1946 Bytes] - [25/12/2016 14:37:28]
########## EOF - C:\AdwCleaner\AdwCleaner[C0].txt - [1787 Bytes] ##########
Log:
# Mode: Clean
***** [ DLL ] *****
***** [ WMI ] *****
