Question my 1050ti going to 82 degree temperature
Thakur_4
Commendable
Aug 7, 2017
63
my specs--
i5 9600k
msi mag z390 tomahawk motherboard
8 gb ddr4 3000mhz ram
cooler master hyper 212 turbo cooler
msi gtx 1050ti oc 4gb
i generally play witcher 3, csgo, apex legends ang gta 5 games. and the tempature of my gpu reaches 82 degree celcius. i have set 83 degree temperature limit.
is my gpu over-heating or any other issues?
my fan curve is attached below
fan]https://imgur.com/a/z9oFV0e[URL='https://imgur.com/a/z9oFV0e']fan curve[/URL]
Apr 9, 2020
29
4
45
NVIDIA says on their website the the max safe temp is 97°C.
I have a 1070 and while stress testing it hits 80°C+ (i have the same limit 83°C) but while gaming it does not get above 70°C so it's possible that you have a bad airflow / dust buildup.
YoAndy
1,270
168
Well your cooler master Cooler is only for your CPU and it doesn't provide any cooling to your GPU, I advise you to install more fans in that case That will improve airflow dramatically and will lover all your temperatures, including CPU and motherboard. That case supports 3 more fans inside the front panel and two on top.
MadsModsat
794
150
640
43
Your fan curve looks just fine, even if you spend a lot of time getting it just rigt, I think the impact on your CPU right now will be minimal - adding a couple of case fans is what I believe will have the biggest impact on the GPU and CPU temperatures more than anything else, compared to your current setup
Reactions: Thakur_4
