Question My 1080 is running at 92- 94 degrees on water block please help
May 24, 2019
5
Hello there thanks for the help I have a fully water cooled i7 8700k rig with a gtx 1080 1 240mm raidiator and an xspc pump reservoir combo and it sees my gpu is reaching 93 degrees on water for no reason whenever I go to use it and I even tried turning the voltage down but running six siege on max settings ony got 15 to 30 fps
