This is everything I am planning to get in a couple of years. I may be ahead of myself, but I think it will be worth saving up for all of these parts. If you notice any problems, please tell me. The only part that I am reusing is my processor, an I5 8400. The revision is U0, which is the same on the motherboard's website, so I'm sure it will work with the motherboard. I am also sending amazon links to each part.
MOBO: https://www.amazon.com/MSI-H310M-PR...=p_85:2470955011&rnid=2470954011&rps=1&sr=8-1
GPU: https://www.amazon.com/MSI-GeForce-...955011&rnid=2470954011&rps=1&s=pc&sr=1-1&th=1
RAM(X2):
https://www.amazon.com/Corsair-2133...ords=ddr4+8gb+2133&qid=1597461422&s=pc&sr=1-3
PSU: https://www.amazon.com/EVGA-100-BR-...HEPTTTW475M&psc=1&refRID=VX88Q7E0GHEPTTTW475M
HDD: https://www.amazon.com/Seagate-Barr...=p_85:2470955011&rnid=2470954011&rps=1&sr=8-7
CASE:
https://www.amazon.com/Phanteks-Ecl...55011&rnid=2470954011&rps=1&s=pc&sr=1-30&th=1
FANS:
https://www.amazon.com/uphere-3-Pac...:2470955011&rnid=2528832011&rps=1&s=pc&sr=1-2
FAN SPLITTER:
https://www.amazon.com/Rosewill-Splitter-Duplicator-Converter-Adapter/dp/B01N0XQ7XC
I hope it will be worth it, as this might be my final personal PC. Of course, things might change in the future, and I might want to upgrade the processor and GPU.
(btw RAM X2 means I'm ordering two. This might sound stupid that I'm not getting a kit, but it doesn't really matter to me. Plus, in the future, I might order another RAM stick. 8 GB will do for now, once the build is completed.
RAM(X2):
CASE:
FANS:
FAN SPLITTER:
