my 1st pc build...help needed
Piyush RUIKAR
12
hello here everyone
i need a review on the below list of components for by 1st pc
intel i7-4790k--- will not overclock atleast for 2 yrs
corsair carbide spec 02
msi z97 gaming 5 mobo
corsair 1866mhz vengence pro 16gb 2x8 gb ram
msi gtx 970 4g
corsair vs650
wd 1tb black
lg 25um65-p
logitech g100s combo
corsair af140 quiet edition
lg normal dvd writer
windows 8.1 genuine.
the total of all above is coming to be about== inr 124852 ie 1943.41$
my budget is not above inr 125000 ie 1955.72$
i will buy windows from official microsoft store...
also tell how the build....i will use it for gaming, rendering and some video editing
i cannot wait for skylake....
thank you....
Get a Coolermaster Hyper 212 evo CPU cooler for it. $30 at Newegg. The CPU will self turbo to 4.4Ghz anyway and will get hotter than its predecessors.
See http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html#xtor=EPR-8886. The VS650 is a tier 3 power supply. For a high end PC like yours, you should get a better quality PSU - from tiers 1 or 2 eg http://www.flipkart.com/seasonic-s12g-550-550-watts-psu/p/itmduvefhzc9pauk
Otherwise - I think you've done a great job putting this build list together. Well done!
after much reviews i have chosen i7 4790k over the e3 1234 v3....
That is a wise decision. You should buy a good cooler for it though. Like a CM Hyper 412 Slim. Or a Noctua D15. If you want to water cool choose a CM Nepton 240M or a Kraken 61.
actuall the stock cooler works best until 4.4ghz of tb but only the time of overclocking ie 1-2 yrs later i will use a liquid cooler.....
also want to ask 1 thing---
is 650w psu sufficient for msi gtx970,4790k,1tb wd black////
It will thermal throttle on the stock cooler, under high load.
+1
