Hello everyone.
Over the years I've relied on this forum for great information from the vast pool of knowledge here.
My 2013 >Micro-ATX< build at Micro-ATX Aerocool DS Cube (265x411x381mm) case:
0. 750W PSU ENERMAX REVOLUTION 87+
https://www.enermax.com/en/products/revolution-d.f.-750w
1. Intel Core i7-4770K Processor (8M Cache, up to 3.90 GHz)
https://intel.ly/3A22dS1
2. ASUS Maximus VI Gene Gaming MB
https://bit.ly/3tpYrkb
3. 16GB (2x8GB) Corsair Vengeance Pro DDR3 DRAM 1866MHz C9 Memory Kit CMY16GX3M2A1866C9R
https://bit.ly/3KaATpA
4. ASUS GeForce GTX770-DC2OC-2GD5
https://bit.ly/3quXRjw
5. Samsung SSD 840 Pro 256GB+512GB / Seq Read 540MB/s Write 520MB/s
6. Cooler Master Hyper 212 Evo
7. Pioneer BDR-208EBK
I originally built this >Micro< ATX "cat" back in 2013 and for almost 10 years she handled everything (gaming) with ease.
2021 tipping point and first bottleneck challenge: "Microsoft Flight Simulator 2020".
The GTX 770 is a pretty decent graphics card, but sadly its Achilles Heel is the 2GB of VRAM. That just will not cut it with FS2020. The problem with FS2020 (and what makes it so awesome) is that all terrain data is unique. All the buildings you see in the game actually exist in real life. So no two are exactly the same. Trees, water and grass are generic and rendered to approximate the real thing, but the uniqueness means that fewer texture files can be re-used over and over again as is the case in video games.
I don't know if I've reached the limits so before I start thinking about new rig, will you please be so kind to suggest the best directions to upgrade my build?
I would gladly take your suggestions for GPU and maybe add something at M2 (M-Key 2242, PCI-E 2.0 x1, SATA3) slot.
My questions:
a. GPU (clearance 320mm or 350mm if I remove the front fan.)
https://aerocool.io/wp-content/uploads/2018/03/DS-CUBE-EOL-min.pdf
My MB ASUS Max VI GENE supports: Quad GPU tehnology (two dual or
AMD Crossfire and Nvidia SLI.
Available Slots:
1x PCI-E 3.0 x16 @ x16
1x PCI-E 3.0 x16 @ x8
1x PCI-E 2.0 x4 @ x4
1x PCI-E 2.0 Mini PCI-E @ x1
*(x16 if single, x8 if dual GPUcard)
b. Monitor DEll U2412M 1920 x 1200 at 60 Hz
https://www.dell.com/en-is/work/shop/cty/pdp/spd/dell-u2412m
c. M.2?
d. RAM of course.
2013 vs 2022
My questions:
- How would you upgrade to maximize the performance, having in mind FS2020?
- How would you upgrade to maximize the performance, overall?
Available Slots:
c. M.2?
d. RAM of course.
- Budget is not an issue as long as there there is reasonable improvement.
- Possible shopping site:
https://www.computeruniverse.net/en/c/hardware-components/nvidia-gpus
2013 vs 2022
