[SOLVED] My 3 meter 2.0 usb extension works on mouse but doesn't work on external hard drive or wifi adapter, how to fix?
Nov 23, 2019
I've recently purchased a 3 meter 2.0 usb extension to place my wifi adapter in a more favorable position. When I tried it out on a mouse, the mouse works fine with the cursor moving on the monitor. But when I tried it on my wifi adapter, the computer detects the device but I couldn't access or use it. My wifi adapter can detect wifi and I can safely remove it but I couldn't connect to any wifi connection
I tried the usb extension on an external hard drive. The computer can detect the device but I couldn't access its contents
I also tried the usb extension on a different computer (a laptop), it also doesn't work properly aside from the mouse.
If anyone can help me in this problem, it would be much appreciated.
Thank you
