My acer aspire e-522 wont turn on or charge. I was usimg it normally whrn suddently it tirmed of and sropped charging. It hasn
imabadsob
Model is aspire e-522.
4years of usage
My acer aspire e-522 wont turn on and wont charge. I was using it when suddently it turned off and stopped charging. It hasnt turned on or charged since. What do i do
NOTE: Yes, I know some batteries are not so easy to get to, on some devices. However, it should be removable/replaceable. Unless it is under warranty, then you should contact the manufacturer first.
Try the following and see if it will turn on...
1. Unplug your charger cord.
2. Remove the battery.
3. Press and hold the "Power" button for 30 seconds.
4. Now plug back in the power/charger cord.
5. Now put the battery back in.
If this doesn't help, then test the power cord to see if it is good. Either try your cord in another device, or try another devices cord in your laptop. You may also want to try charging it when the device is off, rather than on. If it works then, the cord is probably the issue.
Should that not be the problem...
Should that not be the problem, then check the battery to see if it needs replacing.
