my Acer aspire e15 wont turn on. the light in the charging section comes on while charging and i tried removing the battery an
Carlene_3
My Acer aspire won't turn on I tried removing the battery and turn it on but it still won't come on. Am wondering what may be the problem
Try the following and see if it will turn on...
1. First make sure the device has been charged.
2. Unplug your charger cord.
3. Remove the battery.
4. Press and hold the "Power" button for 30 seconds.
5. Now plug back in the power/charger cord.
6. Now put the battery back in.
If this doesn't help, then test the power cord to see if it is good. Either try your cord in another device, or try another devices cord in your laptop.
Should that not be the problem, then check the battery to see if it needs replacing.
