My Alienware 120mm Liquid Cooler do make much noise
Jul 6, 2018
40
Can anyone tell me that making the noise of liquid cooler is normal or not?
Noise is quite loud.
Thanks in advance.
Waiting for your response.
Yes it's normal for fans to make noise as RPM hit maximum because of heat. Some fans are quieter than others but all will make more noise at full speed. Liquid coolers cool slower than air coolers so typically fans would run fast longer. Only way would be to replace fans with better and quieter (and more expensive) ones.
I also want to know one thing more...
I'm using Sapphire Nitro + Rx 580 8gb. I'm running FurMark v1.20.1.0 on 0xMSAA. After sometime (30 secs or more) it stops giving display mean black screen popups and I've to restart my computer to get display again.
Thanks
If Pump makes the noise.
What does it mean?
