Authentication error is often the result of typing the wireless key incorrectly, or typing some of the letters in the wrong case, because wireless keys are case-sensitive.
So open your router's configuration utility and double-check the wireless key in the wireless settings.
When entering that key on your phone, you must type it exactly as it appears in the router config utility.
