Question My AsRock X670E Steel Legend will not power up except for some led's. Where to start troubleshooting?
Dec 18, 2023
Ryzen 7 7700 cpu
WD Black SN850X 2TB SSD
Trident Z5 DDR5 memory 2 sticks
Radeon RX6600 gpu
EVGA 850 BQ psu
Dark Rock Pro 4 cooler
Hyte Y40 case
Remove the discrete GPU from the build, then see if you can get display off the motherboard/iGPU. Which two slots are the rams populating on the motherboard? You will need to elaborate on the model of your ram. Inspect the CPU's socket for any bent or broken pins.
I tried two different psu's and the results were the same - some motherboard led's lit, but there was no power to the fans, the led's, to the gpu or the case peripherals (like the led outline of the on/off switch).. And this is the second motherboard with the same results. To answer your specific question, the two ram sticks
G.SKILL Trident Z5 RGB Series 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6000 (PC5 48000) Desktop Memory Model F5-6000J3636F16GX2-TZ5RK​
are located in slots B2 and B4, as per the instructions. The cpu socket is in great shape. I was fully refunded on the original motherboard.
