Hi, well like I've said in the thread I think my motherboard is dying. So I noticed at first that my PC had started to have graphical glitches, so I though it might be my graphics card, but it seems to be fine, still runs games fine has fine temps and all that as well. Then I turned my PC on a couple of weeks ago and it beeped around 5 times, which led me to find that it meant that my motherboard isn't detecting my card, however the PC still runs fine other than a graphical glitch when I boot the machine after it being off over night (basically only when it's a cold boot), the computer beeping and the Debug screen on the motherboard saying D6, which also relates to it not detecting devices.
So I've been searching for a while now, and a lot of the helpful things I've found have been on these forums, sadly what I've tried so far hasn't worked. Clearing the CMOS didn't do anything, trying the card in another slot didn't help, updating the graphics card drivers didn't work either. Now I'm getting to a point where I'd like to try and pin point the problem, but I can't properly test for the problem, I don't have another PC I can test the card in, nor do I have another card to test in the PC. Assuming you guys try to help out I will be able to answer any questions that can lead to me figuring out what the issue might be and if there is a fix or if I need to get something RMA'd.
System Specs:
i7 3770K Ivy Bridge Socket 1155 LGA
ASRock Z77 Extreme4 (Version P1.30)
8 GB RAM
Gigabyte Radeon HD 7970
Anything else I can get on request.
System Specs:
8 GB RAM
