[quotes=2518469,1,1070905]Hello Guys, What is the normal temp for a asus 5770? While playing games i got 75-85~C temp readings with 90% fan. My idle temp is 45-50~C. Is this normal?[/quotes]
Edit
Never mind.
But temps should be with good air flow ~35c idle and max depending on how high you set the GPU fan speed (higher the better) around 52c-85c. Mine stays at 52c testing with MSIs Kombustor.
