Could be a bad charger, maybe bad motherboard. Anything happen to the system before the issue started? Try removing the battery, remove the CMOS battery from the motherboard and hold in the power button for about 30 seconds. Then with the batteries still out, plug in wall power only and see if it turns on. If it does, replace the batteries and see if it works now.
