My asus laptop led light charger won't turn on even I plug it in a power cable. The charger won't charge my laptop
marjogedaro16
My asus laptop led light charger won't turn on even I plug it in a power cable. The charger won't charge my laptop.
I thibk the main problem is in my charger's adapter. Please help me.
This might help:
power off the laptop
remove battery
press power button for 20 sec
put battery back in
power on
insert charger
if this does not work it is possible that your battery is damaged/old or the charger is not working.
This might help:
remove battery
put battery back in
power on
insert charger
I have no battery mine is Asus and I was playing War Thunder while my phone was plugged up and it just shut off that was yesterday I don't know what to don
Thank you Birne! Your helped me today, this worked a charm on my laptop!
