my asus strix gtx 970 graphics cards led works, fans spin, but i get no signal when i plug it into a monitor
Turn off PC, switch PSU off, hold the power button for 1 minute and try to reboot.
If that doesn't work, try the VGA port instead of HDMI (assuming you're using HDMI in this day and age.)
If both don't work, either take out CMOS battery for 5 minutes, or possibly reseat the 970 just in case.
I have tried all of that, still couldnt get it to work. thanks
No problem.
Can't think of any other solutions off the top of my head besides trying a different monitor/TV. I had this problem with my graphics card not too long ago. About a week ago to be precise. After a several reboots, it just randomly worked for me. despite none of the above things I suggested to you working. Hopefully you're just having the same problem. If not, your GPU might be dead depending on how long you've had your GPU.
thanks for your help. This is my first ever computer and i may have messed up somewhere? but everything seems to work. My Gpu is about 3 days old haha.
lol no problem!
It's hard to screw up a build unless you really try. If everything besides the display is working on the graphics card, there's a really good chance it's something faulty on your end, no offense, it happens to the best of us.
I'd say plug the HDMI or VGA/DVI cord into the I/O ports on your motherboard instead of the GPU itself. Hopefully you have Integrated graphics on the processor to test out your PC. You can then enable the GPU in the device manager when you make it to the desktop.
If the above suggestion doesn't work, i'd say go through this list here:
http://www.tomshardware.com/forum/261145-31-perform-steps-posting-post-boot-video-problems
okay, so what do you think i should do?
Wrong thread?
i accidnelty have two threads, and he posted his answer in this one haha.
Ohhhhh haha, I see.
