My asus x205t laptop will not turn on? Help!
Try the following and see if it will turn on...
1. First make sure the device has been charged.
2. Unplug your charger cord.
3. Remove the battery.
4. Press and hold the "Power" button for 30 seconds.
5. Now plug back in the power/charger cord.
6. Now put the battery back in.
If this doesn't help, then test the power cord to see if it is good. Either try your cord in another device, or try another devices cord in your laptop.
Should that not be the problem, then check the battery to see if it needs replacing.
My battery doesn't come out.
They are all capable of coming out, how easily though is another matter.
If the laptop is under warranty still, then do not open it up. Contact the manufacturer about a repair or replacement.
If it isn't under warranty anymore, you have the option of trying to open it up yourself, or taking it to a local tech/repair shop.
