Solution hang-the-9 Jul 2, 2018 You either set it to max of 80% in the power manager options (you can do that to try to keep battery life longer), or battery is bad.
hang-the-9 Titan Mar 25, 2010 60,368 1,081 152,940 Jul 2, 2018 Solution #2 You either set it to max of 80% in the power manager options (you can do that to try to keep battery life longer), or battery is bad. Upvote 0 Downvote Solution
