Recently, my LCD monitor is having a problem which it never had before
The issue is weird, when i plugged in the power cable only (disconnect the DVI port) the monitor doesnt turn on, the LED indicator did turn on like milisecond and then turn off immidiately. It happens the same when i connect the DVI but not turn on the pc, just turn on the monitor.
But when i connect both cable (DVI and power) and turn on the PC, the screen did turn on but only black dim light, the LED indicator did turn on and last a bit longer (like 3 secs) and then the screen turn back off again.
I did try to change the power cable, tried different power socket in the house but the problem is still there.
How can i deal with this type of problem?
Thanks in advance.
P/s: My display model is BenQ G922HD (a bit old actually)
Thanks in advance.
