Earlier today I decided I was going to build a custom PC. So I started to pick out the component on Amazon as it's easier to buy the part's however, I have come to a halt as i don't know if the components I have chosen will be compatible with one another.
I have also chosen a Corsair CP-9020078-UK Builder Series 750W CS750M ATX/EPS Semi-Modular 80 Plus Gold Power Supply Unit as I don't know whether to use my co-existing EVGA 600w power supply with any of the components listed as I think my old EVGA 80 plus Power supply would be enough. In, addition to this the motherboard I have chosen doesn't give me any confidence whether I can fit the board into an NZXT H440 mid case and if any of the RAM is compatible and would work well.
I am open to all recommendations on the components but I would still like to keep the CPU and 32G of DDR4 RAM with the red and black color scheme. I am also going to be using a GTX 970 as well as the GTX 1080. Could someone provide me with assurances that what they recommend with be compatible and if my build is compatible please help improve it.
Thanks!
Component list:
Thanks!
Component list:
Corsair CMD32GX4M4B3200C16 Dominator Platinum Series 32 GB (4 x 8 GB) DDR4 3200 MHz C16 XMP 2.0 High Performance Desktop Memory Kit - Black
Samsung 750 EVO 120 GB 2.5 inch Solid State Drive - Black
Corsair CW-9060016-WW Hydro Series H105 240mm Rad Extreme Performance All-In-One Liquid CPU Cooler
Intel Core i7 6700K Processor (4 GHz, 4 Core, 8 Threads, 8 MB cache, LGA1151 Socket Box)
MSI NVIDIA GeForce GTX 1080 GAMING X 8GB GDDR5X Graphics Card - Black
MSI B150 Gaming M3 Motherboard (DDR4-SDRAM, DIMM, Serial ATA III, M.2)
NZXT H440 2015 Edition Accent Mid Tower Chassis for PC - Black/Red
