Hey guys,
My Bios seems <mod edit>. Need help pliz.
I am trying to reset it but it KEEPS going back to its initial settings.
The initial setting is an OC to 4.3GHZ which I never did. The default is suppose to be 3.3Ghz with turbo boost up to 3.7Ghz.
These are my parts.
Mobo:ASUS P8Z68 V GEN 3
Cpu : I5 2500K
SSD : Samsung 850 PRO 250GB
ASUS 970 Strix
Windows 7 Pro
So i just reformatted my pc and i wanted my Overclock settings to back to default.
First I tried to load the optimized default settings through bios. Motherboard starts up twice and still keeps the old settings.
Second, I tried taking out the CMOS battery for 30mins. It resets but it goes to the American Megatrends screen with my only option to click F1 to restore old settings ( WTFFFFFFFF)
Third, I tried resetting the mobo by the jumper method. Goes to the same American Megatrend screen and gives me the F1 option to restore old settings WTF.
HOW THE <mod edit> DOES IT EVEN STORE OLD SETTINGS AFTER A HARD RESET??????
I have updated my mobo to the latest bios (3603) directly from ASUS.
ALSO I installed the AI SUITE and in the Auto tuning section it says http://i.imgur.com/FWVgYhY.png
and http://i.imgur.com/1ZVCq0S.png
And this happens I try the CMOS reset. http://i.imgur.com/Ok61nW3.jpg
I have no idea what to do next.
EDIT: I found a link with exactly the same problem with the exactly same Overclock of 4.3Ghz. http://www.tomshardware.com/forum/276342-29-turn-turbov
<Moderator Warning: Watch your language in these forums>
These are my parts.
Cpu : I5 2500K
ASUS 970 Strix
Windows 7 Pro
