alokambar Reputable May 20, 2015 44 0 4,530 Sep 16, 2016 #1 Took connection of 10 Mbps but the browsing is slower than fixed broadband 512 kbps speed connection
Solution Hlsgsz Sep 16, 2016 alokambar : Hlsgsz : Because it's a worse quality connection, even if it's advertised as 10Mbps. You can use SpeedTest to assess the raw throughput of your connection and PingTest to assess it's quality. Ping is very high its around 400 ms, how can i reduce it? Thats why the connection is bad. If you are on wireless, connect a cable instead. No other way to reduce it.
Hlsgsz Champion Feb 29, 2016 8,003 5 51,415 Sep 16, 2016 #2 Because it's a worse quality connection, even if it's advertised as 10Mbps. You can use SpeedTest to assess the raw throughput of your connection and PingTest to assess it's quality. Upvote 0 Downvote
alokambar Reputable May 20, 2015 44 0 4,530 Sep 16, 2016 #3 Hlsgsz : Because it's a worse quality connection, even if it's advertised as 10Mbps. You can use SpeedTest to assess the raw throughput of your connection and PingTest to assess it's quality. Ping is very high its around 400 ms, how can i reduce it? Upvote 0 Downvote
Hlsgsz Champion Feb 29, 2016 8,003 5 51,415 Sep 16, 2016 Solution #4 alokambar : Hlsgsz : Because it's a worse quality connection, even if it's advertised as 10Mbps. You can use SpeedTest to assess the raw throughput of your connection and PingTest to assess it's quality. Ping is very high its around 400 ms, how can i reduce it? Thats why the connection is bad. If you are on wireless, connect a cable instead. No other way to reduce it. Upvote 0 Downvote Solution
