Hello guys, Im building a new gaming pc, but am waiting to get a 290x, it seems like the best choice for "future proofing" and value. This will be my first build.
Are you thinking about getting a 290x too?
Are you planing a new build too? If so feel free to post it, Iv love to see it.
so what do you think, is there anything I could improve?
CPU- I7 4770K
(For next gen games)
CPU Fan- Noctua NH-14
MOBO- Asus Z87-A
(Should I get a pro sabertooth for better cooling (for better heat-sinks, armour)?
GPU- Non reference 290x
? sapphire toxic ?
(Will Upgrade to crossfire down the line)
RAM- G-Skill Sniper
(Cheap, Looks good in most rigs (Black), Dont need more than 8GB's probs 4GB would be ok.
SSD- Samsung 250GB EVO, already have two 500 GB HDD's,
Will the Mobo fit all three?
Sound card- Asus Xonar Essence STX 24-bit 192 KHz
(I would like to get onto my music a bit more)
Is a inbuilt sound card really a replacement for a true purpose made one?... Really I don't know.
Case- Cooler master HAF 912
Will the mid case be sufficient space and air flow? is there a better case for performance? Id like a more plane looking case, like the bitfenix ones, but air flow is more important. Is a cooler master one the best for that? Should I go full tower?
Power- Silverstone Strider Gold Evolution 1000W 80 PLUS Gold
(Cheapest 1000w one I can find)
Is this overkill? I do wont crossfire 290x later, and inbuilt wifi later.
OS- Windows 7 home edition
(Is windows 8.1 Light years ahead than 7 in any way?)
DVD- already have one from laptop (blue ray).
(same connections as Desktop one's, but just mite sit funny in case..... HAY! ITS FREE OK!
DON'T JUGE ME!
Thanks for your time, what do you think?
CPU- I7 4770K
MOBO- Asus Z87-A
RAM- G-Skill Sniper
DON'T JUGE ME!
